Bandwidth Issue
rk6171485
Dear Cisco Support,
Greeting of the day
i have an issue with the bandwidth. i have a ILL of Reliance JIO 50MBPS. when i checked on laptop direct through line Customer end. i am getting total of 50mbps speed but when is plugging link wan port on router and then also check from lan port side then i am checking speed test, after speed test i am getting download 7 mbps and upload 50 mbps.
requesting you to please understood this scenario and help me what can i do from my side.
show int fa0/0
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is dc7b.9479.7798 (bia dc7b.9479.7798)
Internet address is X.X.X.X/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 254/255, txload 2/255, rxload 9/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 19
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3610000 bits/sec, 533 packets/sec
5 minute output rate 999000 bits/sec, 410 packets/sec
49487798 packets input, 1629246982 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
2691427 input errors, 2691368 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
30302925 packets output, 4242677157 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
6 Replies 6
Jitendra Kumar
this is not cisco tac support this is the volunteer's cisco community
have you checked with 1000mbps speed full manually set both devices ( router and JIO )?
Jitendra
Dear Jitender,
Greeting of the day
I have checked JIO ILL direct on laptop and i am getting full speed on laptop. but when i was plug on router WAN port then check through router lan port from connect with laptop then i am getting Download 7 and upload 50 speed.
Thanks & Regards
Rajan
you need to check below thinks first
1. check ISP router/modem interface speed its manual set or auto-negotiation.
Mostly ISP service providers leave it auto so in that case, you need to set your router interface as auto assuming the isp router interface is on auto-negotiation and you have configured speed manual 100mbps duplex-full.
Set interface auto negotiation and check.
Jitendra
Georg Pauwen
as stated, the interface shows a massive amount of input and crc errors, which point to a physical problem with the cable and/or the port. Try another port and change the cable (make sure you are using something like Cat6 or higher...)
i am using cat6 cable and also I have change the cable.
what about another port ?
