Bandwidth Mangement
sreekanth sarma
Hi all i have 14 Mbps bandwidth provided my ISP and terminated in a 2801 router and PAT configured over it,behind lies my ASA 5520 with NAT exemption and the traffice to outside from inside users come from 3 Proxy servers whose Gateway is a Core switch behind the firewall.
Now i want to manage my Bandwidth for all the 3 proxy servers limiting the usage of it, i tried it over my ASA 5520 with class-map and policy-map command and by using policing over my outside interface
but its not working i am unable to limit the usage,i am attaching a model of my network
what went wrong in my configuration please let em know
5 Replies 5
sreekanth sarma
Here i am enclosing my configuration
access-list proxy-server1 extended permit ip any host 172.16.12.x
access-list proxy-server2 extended permit ip any host 172.16.12.x
access-list proxy-server3 extended permit ip any host 172.16.12.x
class-map proxy-server1
match access-list proxy-server1
class-map proxy-server2
match access-list proxy-server2
class-map proxy-server3
match access-list proxy-server3
policy-map qos
class proxy-server1
police 1000000
class proxy-server2
police 1000000
class proxy-server3
police 1000000
service-policy qos interface outside
HI any body here 2 suggest me?
Hi can any one solve the problem ? or do u suggest where else can i post this query?
hi sree
why dont u take public ips from the isp and nat the same in your ASA ?
Based on the IP's you can do either CAR(rate limit)arrangement or class based policing.
Also you can ask the ISP to do the same at their end so that its uniform on both the ends for both outgoing and incoming traffic.
regds
Hi prem
thanks for ur reply sorry for delayed response as i am bit busy in another work,i dont wabt my ISP to involve in the regard
So what can i do ?
