Bandwidth monitoring
Izac ICT
Hello all,
I like to see who or what is using most of the bandwidth (top consumers). My setup is like below. Cisco C3750 switch is connected to juniper srx cluster. Every connection is shared by firewalls via cisco switch. I like to monitor the bandwidth via Solarwinds real-time-bandwidth-monitor (or any other free tool you advise :)) I tried on juniper srx cluster with prtg but result was not good and srx cluster mode only support jflow(netflow) version 5.  Please advise where and how can I monitor properly?
Thank you.
Isac
julian.bendix
Level 7
Level 7
Hi!
This should help you:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html
You could configure NetFlow on Gi 1/1/1 on the Catalyst 3750 and export the flows to your SolarWinds.
Let me know what you think.
Best regards
Juls
