Bandwidth
w_basheer
Level 4
Level 4
Dears;
I need to do some check on a network in terms of bandwidth, redundant links to check for any upgrade needed.
currently i don't have any software.
how can check this?
Richard Burts
Waleed
You have posted this same question of the forum of Getting Started. It has received a response which you indicated solved your request. If there is to be any more discussion of this it should be consolidated in the Getting Started forum.
Rick
Rick
