Batch send cli commands using Prime Infrastructure
kj9000
Frequent Visitor
Frequent Visitor
Is it possible to automate a batch send of a cli command to several switches using Prime Infrastructure?
We have about 300 switches on which I would like to issue the "software clean "command. I would like to automate this rather than logging into 300 switches but this command requires a yes or no answer before completing the task.
Thanks in advance.
jhz
Visitor
you might be able to use a CLI-based template in prime to accomplish this.  The template would have the command.  Then you would apply it to all the devices.
iportuga
