06-08-2018 06:58 AM - edited 03-01-2019 06:37 PM
Hello all,
I am in an enviroment with hundreds of 3850's and 2960's that I need to pull and give a report on the number of POE ports in use per switch.
I essentially need to do "show power inline" on every switch and give a report on this.
We have Cisco Prime and PRTG.
Any one have a clue how to do this? I am about to just run a script to do it, however that wont necessarily put everything in nice pretty report.
Solved! Go to Solution.
06-10-2018 06:57 AM
Cisco Prime LMS used to have a "netshow" utility however Cisco hasn't seen fit to port that into Prime Infrastructure.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw21935
One contributor came up with a clever work around that may be useful:
On the other hand, it's a great excuse to learn one of the open source automation tools and get started with a problem at hand. Look into netmiko or similar tools and get started down the path to being a "full stack engineer".
06-08-2018 08:21 AM
I think the best option here would be to use a script. You could use a tool such as Manage Engine Device Expert to execute this against each of the switches you have. The output will likely be a text file that you would need to submit to an FTP server on your infrastructure.
Someone may be able to suggest a tool that could output this information into a report for you.
06-08-2018 04:25 PM
06-10-2018 06:57 AM
06-14-2018 06:55 AM
I figured this would be the general answer. I do have a PowerShell script that lets me execute commands on all my devices, but its not nearly as refined as that Netmiko. I am going to have fun with that! Thanks
