BDI Statistics are not getting incremented in ASR 903 RSP3
Sylvia
Product: ASR 903
Version: 3.18.2SP RSP3
Problem: Counters are always zero or showing very small traffic when running 'show interface bdi' or 'show platform hardware pp active interface statistics bdi' even tho there is traffic passing through the interface
Troubleshooting: I saw many bugs regarding this issue but none of them applies to this version (CSCuf86247, CSCuh46103, CSCuf86247, CSCur76549). I also tried version 3.16.5S but problem persisted.
Is there any workaround for this issue as Monitoring BDI interfaces is very critical to us!
Hi Sylvia,
BDI statistics is not supported on the RSP3 module.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cether/configuration/xe-3s/asr903/16-9-1/b-ce-xe-16-9-asr900/b-ce-xe-16-9-asr900_chapter_01011.html
UPD: Starting Cisco IOS XE Fuji Release 16.9.3, BDI statistics is supported on the RSP3 module. The show interface command displays the BDI statistics for the interface.
https://www.cisco.com/c/en/us/td/docs/routers/asr903/release/notes/16-9-1/b-rn-xe-16-9-1-asr900/b-rn-xe-16-9-1-asr900_chapter_01.html
This answer for history)
