Best management cisco software
nunoscosta
Hello guys!!!
What is the best software for alarms, graphic about network loads and device management?For cisco devices only!!!
Marvin Rhoads
There's no one size fits all.
Cisco's enterprise class solution is CiscoWorks LMS: http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html. It's a very full featured configuration and fault management tool. It's performance management capabiliites are lacking in areas most folks are looking for and many CiscoWorks shops often end up using a third party tool such as MRTG (open source) or Solarwinds for performance monitoring. LMS will set you back on the order of US$20,000.
A small Cisco-only shop may get by with Cisco Network Assistant, a rudimentary tool with limited device support. See the product data sheet for details: http://www.cisco.com/en/US/products/ps5931/index.html. The price is right - free
Solarwinds (http://www.solarwinds.net/) and Whats Up Professional (http://www.ipswitch.com/products/whatsup/professional/index.asp) are two good third party tols that many folks use happily. Solarwinds runs about $3-4,000 once you buy all the components and What's Up about $2-3,000.
Martin Ermel
you could also have a look at REALTECH theGuard (vendor independant). With its newest release it also has a web gui and config management.
http://www.realtech.com/wInternational/software/network_manager/netman_overview.php
Thank you guys for the feedback.
ahajivandi
Some could have mentioned this product; HP-OV NNM
If you can afford it, then it is almost the standard Network management software : Moreover, you can adopt it with your environment (250 nodes and more..)
http://www.openview.hp.com/products/nnm/index.html
