Best method to rotate syslog_info on LMS 3.2
eidumsigfrid
What is the best method to rotate the syslog_info file on Solaris?
Currently I have been using logadm which I think is causing issues.
Cheers,
Sigfrid
Joe Clarke
You should use the included /opt/CSCOpx/bin/logrot.pl script.  You can configure log file rotation under Common Services > Server > Admin > Log Rotation.
If you must use logadm, use the -c option to make sure the inode number doesn't change when rotating syslog_info.
