Best telnet and TFTP freeware application
nunoscosta
Hello guys...
Imagine that you have many devices and you want to group each them in one application by type or something like that to connect by terminal (telnet/ssh etc...). Do you know some freeware application for that? like RoyalTS but for cisco devices. Last question is... TFTP servers, a good one but freeware?
Thank you again for you knowledge!
Best regards.
Hi!
I would recommned PuTTy for telnet/SSH needs. Although you can't group devices in it, you can always save the devices by their names and IP add. Its a good freeware application.
Solarwinds TFTP server is one of the best TFTP server if not the best TFTP server availbale for free download.
Click the following links for downloads:
PuTTY --> http://www.putty.nl/download.html
TFTP Server --> http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
More Telnet/SSH Clients --> http://www.softpedia.com/get/Network-Tools/Telnet-SSH-Clients/
Hope it helps.
Please rate all posts.
AbhisheK
nunoscosta
:) Thank you very much! I will try these!
Best regards...
You are welcome!
AbhisheK
miheg
Level 5
Level 5
Putty is the tool for Telnet/SSH.
Check out tftpd32 as a tftp server and tftp client
It can also do syslog and be a DHCP and SNTP server.
And it's free to use.
Cheers,
Michel
