best way to monitor traffic on routers
preston
I did some basic snmp monitoring to see what my utilization is on some routers. I would like to be able to break that down by the type of traffic, in high utilization spots. (just the wan links)
If I do a
#ip flow-cache timeout active 1
#ip cef
#ip flow-export version 5
Will that interfear with my routing or connections, I can't afford to take a router down. Is there anything to watch out for?
Is useing netflow the easiest way to put together a quick snapshot, any good tools to use for this?
Thanks in advance
5 Replies 5
peter.nowack
after enabling ip route-cache flow on interface and ip flow-export you will receive netflow exports. In the netflow you can see all flows that are received on the interface where you set ip route-cache flow... We used CESNET NetFlow Monitor it is free, but it has many disadvantages. We bought Caligare Flow Inspector software (http://www.caligare.com) this year and we are very happy with it. Last week we were under attack, and we easy found our infected workstatation ;o)
Have a nice day,
Peter
Does enabling ip route-cache flow, have any effect on the routing or current connections when I turn it on.
Basically is it safe to turn on without worry, like snmp?
I think, that is it safe. We turn on without any power loss.
Peter
It's certainly a valid concern - and to satisfy customers Cisco produced the following Netflow Performance Analysis white paper:
http://www.cisco.com/en/US/tech/tk812/technologies_white_paper0900aecd802a0eb9.shtml
If you have enough flows for it to be a concern then there is always sampled-netflow.
Andrew.
preston
IP CEF kills the connection!
Just a heads up if someone reads this post, luckily I tested it, when you turn on IP cef it killed my pings.
Is there anyway to turn on Netflow monitoring without bringing anything down?
