BFD configuration in NCS 520
fcardoso
I'm trying to configure bfd, to improve convergence times between ebgp neighbors... I'm using an NCS 520 with the "metroipaccess" license...
Has anyone tried this?
--- under the bdi´s interface:
"bfd interval 50 min_rx 50 multiplier 3"...
**gives error: % Invalid input detected at '^' ma....
---inside BGP:
bgp router 64700
address-family ipv4 vrf IBMGMT
neighbor 10.100.100.25 fall-over bfd
**it is OK
Fernando
8 Replies 8
Check below
MHM
Hi MHM,
Thanks for the reeply.....
The document explains it very well, but it is for ios XR, in my case i have iOS XE:
Cisco IOS XE Software, Version 17.09.05a
Cisco IOS Software [Cupertino], NCS520 Software (LINUX_IOSD), Version 17.9.5a
Fernando
Bdi interface or bvi interface?
Did you try bfd template ?
MHM
***I tried template configur globaly:
NCS(config)#bfd-template ?
% Unrecognized command
NCS(config)#bfd ?
NCS(config)#b?
banner beep boot boot-end-marker
boot-start-marker bridge bridge-domain buffers
bulkstat
## No bfd option......
***I tried template configur inside BGP:
NCS(config-router)#router bgp 64700
NCS(config-router)#template peer-session xxx
NCS(config-router-stmp)##?
BGP peer-policy configuration commands:
ao TCP-AO authentication
bmp-activate Activate the BMP monitoring for a BGP peer
cluster-id Configure Route-Reflector Cluster-id (peers may reset)
default Set a command to its defaults
description Neighbor specific description
disable-connected-check one-hop away EBGP peer using loopback address
dont-capability-negotiate Send Capability parameters in Open
ebgp-multihop Allow EBGP neighbors not on directly connected networks
exit-peer-session Exit from template configuration mode
fall-over session fall on peer route lost
ha-mode high availability mode
inherit Inherit a template
local-as Specify a local-as number
log-neighbor-changes Log neighbor up/down and reset reason
no Negate a command or set its defaults
password Set a password
path-attribute BGP optional attribute filtering
remote-as Specify a BGP neighbor
shutdown Administratively shut down this neighbor
timers BGP per neighbor timers
transport Transport options
ttl-security BGP ttl security check
update Modify update processing
update-source Source of routing updates
version Set the BGP version to match a neighbor
OK o followed the doc and i have the configur:
interface GigabitEthernet0/0/18
no ip address
no negotiation auto
cdp enable
lacp rate fast
service instance 111 ethernet
encapsulation dot1q 111
rewrite ingress tag pop 1 symmetric
bridge-domain 111
interface BDI111
ip vrf forwarding XXX
ip address 10.100.100.26 255.255.255.252
end
Then i tried to configure:
VIR-NCS-01_LAB(config)#interface BDI111
VIR-NCS-01_LAB(config-if)#
VIR-NCS-01_LAB(config-if)#bfd interval 100 min_rx 100 multiplier 3
% Invalid input detected at '^' marker.
VIR-NCS-01_LAB(config-if)#bfd ?
VIR-NCS-01_LAB(config-if)#b?
bandwidth
#no bfd option.....
interface BDI111
ip vrf forwarding XXX <<- only for test remove vrf and check bfd
OK, did not resolve:
interface BDI111
end
NCS(config-if)#
NCS(config-if)#int bdi111
NCS(config-if)#
NCS(config-if)#
NCS(config-if)#bfd
