Block Url
tbarberio
I have Pix 515E i have a specfic url that i want to block. I relaize i can instal a server like websense or the like but i feel that is overkill to just block this 1 url. Is there a rule i can add in to the pix to not allow to go to that site? I don't care if the ie error comes up or it redirects somewhere else. Please advise Thank you
Collin Clark
In your internet router, you can send the IP to null0. That would block the IP, not just the URL.
HTH and please rate.
Since the pix sits as the last piece of equipment it technially also routes the internet traffic so is there a specfic command i can issue to block the ip?
A couple of choices then. You could route that specific IP to somewhere else (not suggested) or create a more specific Deny statement in your ACL blocking port(s) to the IP.
HTH and please rate
