03-26-2024 05:10 AM
We shall install a lot of NCS-520 normaly it get the config over ZTP, but by default it starts up with metroaccess that is not supporting BGP etc. I want to save the 10 min for etch for the reboot to do the change to metroipaccess
We will make a software upgrade before the installation, so we are able to put a extrafile or script on the device, the most important this is the ZTP is working on the installation.
Is it possible?
03-26-2024 06:32 AM
not really sure what you are asking. You want the router(s) to boot with ZTP ? Do you have ZTP enabled globally, and configured a URL for ZTP ?
NCS520#conf t
NCS520(config)#ztp
NCS520(config)#ztp url http://ztp-server.example.com/configs/ncs-520.yml
03-26-2024 06:41 AM
no, can see the confusion. we are sending the config to the cpe the old way, we are using the dhcp, and the device is getting the config over tftp.
so i ask for, a way where we can start the device up in metroipaccess mode.
as it is now we have to
conf t
license boot level metroipaccess
end
reload
before it starts up with metroipaccess
and i can put on the bgp part again since it drops tat in the first step because it is unsupported.
i hope the issue is more clear now
03-26-2024 11:59 PM
unfortunately the only way (I know of) to change the license level is to reboot the device. I have never seen another way. The command 'reload warm', if available on the NCS520 might speed the process up a bit...
