Botched engineId
Andreas Bostrom
I have encountered a very strange problem when configuring remote target engineId on a Catalyst 3750 switch. The switch changes the engineId, it puts a zero between the two last digits. As shown below it changes ...e166 to ...e1606. I have tried with removing the user, rebooting the switch and re-adding the user but the switch changes the engineId every time. I have configured tens of switches in the exact same way and has never come across this problem before. Does anybody know what the problem might be?
sw21(config)#snmp-server engineID remote 10.5.9.6 udp-port 1162 b7a9d3ca99325e6b5fb2894a500e166
sw21#show snmp user
User name: trap
Engine ID: B7A9D3CA99325E6B5FB2894A500E1606
storage-type: nonvolatile        active
Authentication Protocol: SHA
Privacy Protocol: None
Group-name: sysadm
sw21#show version
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE5           C3750E-UNIVERSALK9-M
     2 30    WS-C3750X-24       12.2(55)SE5           C3750E-UNIVERSALK9-M
Best regards,
Andreas Boström
Systems Engineer
Andreas Bostrom
See
http://networkengineering.stackexchange.com/questions/2144/ios-changes-the-snmpv3-engineid
The problem is that the engineId is 31 characters long and therefore not a valid hex number.
