Prime Infrastructure blocks SNMP during sync causing PRTG alarms
bkoch1
We're running Prime Infrastructure 1.2, and until yesterday we were mainly using it for wireless monitoring. We use PRTG for monitoring the state of the rest of the network. I added our core router (6509-E w/VSS), and during syncs, we will get PRTG alarms (SNMP traffic sensors) saying "No response". The downtime is ~5 minutes (which is the PRTG scanning interval). So, it seems like Prime is preventing other SNMP traffic during the syncs. Is this normal? I don't really like the thought of receiving a boatload of false alarms several times a day.
Zoran BKV
I can confirm this behaviour. Our HP P2000 Controller has stop responding since we started syncing. We just get SNMP error 2003. Also using PRTG to monitor systems.
Rollin Kibbe
Hi Brian:
Prime Infrastructure 1.2.0.103 was deferred and removed from Cisco.com in favor of 1.2.1.12, for a number of issues.  The current release is 1.3.0.20 Update 1.  Between the two, there have been a number of fixes with regards to Java threads being locked, amount of system resources being used by the Oracle engine, size of the backups, and a lot more.  You may want to look into getting current to see if the behavior changes.
Clarifying the upgrade path to Prime Infrastructure 1.3.0.20 Update 1
Given the volume of data polled during sync cycles, I could see where Prime Infrastructures questions might dominate or even overwhelm the router's SNMP agent, but there's no process that puts an access-list to prevent the agent processing any other station's traffic while sync is going on.  You may want to check the CPU utilization of the SNMP agent (show process cpu | i SNMP ENGINE) before, during and after the sync to see what impact the sync has.
