C1240 AP
lni1
Recently we installed some C1240 AP's, unfortunately in Ciscoworks they are not recognized as AP, they remain in the section unknown devices. When I try to download a device package, Cisco responds that there are no packages availabe, what can be the problem ? In the classifications of CW I can't find it either.
10 Replies 10
David Stanford
This sounds similar to bug CSCsc68458
In this case the AP's were reporting an incorrect sysObjectID. What is the sysObjectID reported for the AP?
This happens when the AP's go from lwapp to IOS conversion and affects code 12.3(07)JA02.
This makes it unmanageable by NMS apps
including WLSE and LMS. The fix for this problem is a code upgrade.
However, it could also be due to snmp timeouts while querying the CISCO-FLASH-MIB on these devices. try increasing snmp timeout to 60 seconds and resubmit the devices.
Hello Davistan,
I tried to increase the snmp value, but no result.
On the back is noted : AP1242AG, in CW I found :
1100 series WLAN Access Point with 1 10/100TX port, 1 IEEE 802.11 radio port
IOS is 12.3(7)JA1
What do you mean by code upgrade ? (soft upgrade ?)
Can you do an snmpwalk of sysObjectID? What value does it return?
Hello Davistan,
system.sysObjectID.0 : OBJECT IDENTIFIER: .iso.org.dod.internet.private.enterprises.cisco.ciscoProducts.685
So it corresponds with the Cisco Aironet 1240 series access points, it's in the list of supported devices, now what, any thoughts ?
Many thanks
Lieven Stubbe
Belgian Railways
what value did you increase the snmp timeout to? What version of RME are you running?
RME 4.0.3
In "Admin > System Preferences > RME Device Attributes" I increased the value from 15 to 60
Many thanks for your contribution
Lieven Stubbe
Belgian Railways
In the devicelist I can't find an OID like
1.3.6.1.4.1.9.1.685
I tried everything, still no change.
I really need a solution for this problem, we have already deployed 50+ such AP's and I don't feel to configure these manually !!
Many thanks
Lieven Stubbe
What does Check device credentials report for these devices?
you might want to turn on some inventory debugs and remove/add these problems devices (start with one only)
Remove it from the DCR
Then go to:
RME-->Admin-->System Preferences-->Loglevel Settings
Select ICServer and change from Info to Debug for all 3 items. Then try
to add the AP again and look in the IC_Server.log file to see if there are any errors.
The CDR says failed everywhere.
I changed the Loglevel settings for the ICServer to Debug and here are the results when I do a delete/create of the node,
it doesn't say much to me, perhaps you see more,
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-24],com.cisco.nm.rmeng.inventory.ics.core.ICSCore,173,Got Async Request, User Name :admin
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-24],com.cisco.nm.rmeng.inventory.ics.core.ICSCore,179,Request ID is : 1161350734458
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,155,Started processing device ID: 2471
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,194,Started processing device Name: 10.2.51.200
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,239,DP time is 0 seconds for 10.2.51.200
[ Thu Oct 26 09:49:19 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,882,New device added
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,995,About to update DM for DeviceID 2471
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,1001,Updated DM for DeviceID 2471
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,454,Total time before Callback is 1 seconds for 10.2.51.200
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.util.logger.RMELogger,724,com.cisco.nm.rmeng.inventory.ics.dm.ICSDMCallback,icsCallBack,82,Called DM, status 5 for Device 2471
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,457, Finished processing device 2471 10.2.51.200
[ Thu Oct 26 09:49:20 MEST 2006 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,463,Total time is 1 seconds for 10.2.51.200
I also did NMS to device :
Test Results
HTTP Okay
sent: 5 recvd: 5 min: 36 max: 36 avg: 36 timeout: 2 size: 33 protocol: http port: 80
TFTP Failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 25 protocol: tftp port: 69
SNMPRv1/v2c Okay
sent: 5 recvd: 5 min: 1 max: 2 avg: 1 timeout: 2 size: 91 protocol: snmp_get port: 161
SNMPWv1/v2c Okay
sent: 5 recvd: 5 min: 1 max: 1 avg: 1 timeout: 2 size: 99 protocol: snmp_set port: 161
SSH Okay
TELNET Okay
Here everything is fine, but in DCR everything marks failed, I don't get it !!!
Anyway, many thanks in advance for your support
Lieven Stubbe
Belgian Railways
AP1240 support wasn't added until RME 4.0.5. If you do not have version 3.0 of the RME AP1200 device package, then you do not have support for this AP.
You should upgrade to LMS 2.6 which is a free download on Cisco.com. That release comes with AP1240 support out-of-the-box.
