C2950 swtich port storm-control
boblee
how to calculate the percentage (or threshold) of the broadcast storm need to be block for c2950 switch? e.g I have a 100M FE port has an average of utilisztion of 50Mps,should set it to 50%?
spremkumar
Level 9
Level 9
It depends upon the amount of broadcast traffic which u need or can tolerate in each port of the switch.
We had the same configured for a limit of 20% that basically defines the amount of broadcast traffic nothing other than that.
you can also include multicast traffic in conjuntion to that and if required out there in your network..
regds
Hi,Thanks for your rapid response,but how i capture the trap for broadcast storm-control though snmp?
Regards!
