[C4507R+E] DHCP Binding IP Address display issue (Version:3.3.2XO)
chaejungho
※ C4507R+E, DHCP Binding IP Address display issue (Version:3.3.2XO)
I have been using the DHCP server function of the Cisco switch.(C4507R+E)
And, I have been using the recommended Version from Cisco (3.3.2XO)
but, DHCP Binding IP Address Display Problems found.
IP Address last number no display.(192.168.220.19X)
Although the test with a higher version of "3.7.0,3.6.0", is the same phenomenon
is this a problem that cisco ios display bug?
And i haven't found in cisco bug tool.
yet, Is the bug did not find?
How can you solve this problem?
Please tell me the solution.
Note that although performing a "terminal width" command, the phenomenon is the same.
This is not a terminal program issues.
See below for details
“When compared to the ARP tables, IP / MAC address will recognize the problem”
1.Device Name and Version
C4507R+E#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M),
Version 03.03.02.XO RELEASE SOFTWARE (fc1)
License Information for 'WS-X45-SUP8-E'
    License Level: ipbase   Type: Permanent
    Next reboot license Level: ipbase
2.DHCP binding status of the problem
C4507R+E #show ip dhcp binding
Bindings from all pools not associated with VRF:
IP address      Client-ID/              Lease expiration        Type       State      Interface
                Hardware address/
                User name
192.168.220.19  018c.3ae3.9446.13       May 25 2015 12:32 PM    Automatic  Active     Vlan220
192.168.220.19  01b8.ee65.4039.fc       May 25 2015 11:37 AM    Automatic  Active    Vlan220
192.168.220.19  0130.d6c9.175f.6a       May 18 2015 01:38 PM    Automatic  Active     Vlan220
----Omission----
C4507R+E#show ip dhcp binding 192.168.220.19
% Adddress 192.168.220.19 is not in the database.
C4507R+E#show ip dhcp binding 192.168.220.193
                Hardware address/
                User name
C4507R+E#show ip arp 192.168.220.193
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  192.168.220.193         0   b8ee.6540.39fc  ARPA   Vlan220
0 Replies 0
