12-13-2019 12:16 AM - edited 12-13-2019 12:19 AM
When we are using the switch as standalone they come up in prime.
When we activate Stackwise Virtual it comes up as unsupported device in prime.
We are using Cisco IOS XE Software, Version 16.12.01c on the switches.
When I look through the release notes of different software versions I can not see that prime 3.7 is supported for this device.
https://www.cisco.com/c/en/us/support/switches/catalyst-c9500h-24y4c-switch/model.html#ReleaseNotes
My question is when will there be a software for C9500-24Y4C that supports prime version 3.7
Solved! Go to Solution.
12-13-2019 01:29 AM
- It's usually the reverse; will there be a version of Prime that supports you configuration. You can also verify the current setup against :
M.
12-13-2019 01:29 AM
M.
12-13-2019 03:10 AM
12-17-2019 05:57 AM - edited 12-17-2019 06:12 AM
I remember those days when the Cisco engineers stood on stage and said there will not be a release of a new Cisco platform that was not also supported in Prime when released. Not even the documentation is updated:
6 months and nothing has happened. We are at 3.8...
Is 9500 in stackwise virtual setup that uncommon?
What is the roadmap for support?
DNAC suported this setup in 1.3.1.3
So since there is a no documentation of support matrix the procedure is to install/upgrade to 3.7 and THEN check.
Supported Devices
To see the list of devices supported in this release of Prime Infrastructure:
Procedure
Step 1
Log in to Prime Infrastructure.
Step 2
Click the wheel icon at the top right, then click Supported Devices.
10-15-2020 06:10 AM
First I have to agree that a C9500-24Y4C in VSL is absolutely NOT uncommon. I have more than one customer with that setup. And also that updates to the documentation is a bit lacking for Prime Infrastructure.
Now for the good news, it seems to be supported now in 3.8. Can someone confirm this?
| Note - SVL supported for C9500-24Q,C9500-12Q,C9500-40X,C9500-16X,C9500-32C,C9500-32QC,C9500-48Y4C,C9500-24Y4C |
