Campus Manager 5.2.2 Application error: SQL Anywhere Error -143: Column 'Device' not found.
William Ryan
When pulling information through Campus Manger, User Tracking and pulling Device or Device Name for IP Phones, the following error is generated.
"Application error: SQL Anywhere Error -143: Column 'DeviceName' not found.".
All othe functions work.
Any suggestions?
1.Campus Manager5.2.223 May 2011, 09:59:29 CDT
2.CiscoView6.1.923 Feb 2010, 08:57:28 CST
3.CiscoWorks Assistant1.2.023 Feb 2010, 08:57:28 CST
4.CiscoWorks Common Services3.3.123 May 2011, 09:59:29 CDT
5.Device Fault Manager3.2.123 May 2011, 09:59:29 CDT
6.Health and Utilization Monitor1.2.223 May 2011, 09:59:30 CDT
7.Integration Utility1.9.023 Feb 2010, 08:57:29 CST
8.LMS Portal1.2.123 May 2011, 09:59:30 CDT
9.Resource Manager Essentials4.3.223 May 2011, 09:59:30 CDT
Gaganjeet Chug
Level 4
Level 4
Hi William,
Hav you installed any Device packages for Campus Manager ?. If yes, kindly try deleting it and then restart the daemon manager again with the command :-
net stop crmdmgtd
net start crmdmgtd (wait for 20 minutes before logging to CiscoWorks)
Also, kindly share the pdshow output along with ani.log
Many Thanks,
Gaganjeet
Svetlana Radzevich
William,
did you get the error when you created a custom reports for IP Phone using the Report Designer? If not, please explain how you pulled the information.
Svetlana
There has been no changes, this is from pulling a User Tracking Report, Quick Report for IP Phones. If you use anything other than Device and Device Name, information is there, to include information in the Device and Device Name columns. So the information is in the database. The error occurs whrn you try to pull information using Device or Device Name. Pulling reports this way has worked with no issues in the past.
Here is what is in the ani.log
2011/09/07 06:39:23 NewMACPoller ani MESSAGE DBConnection: Created new Database connection [hashCode = 30335449]
2011/09/07 06:40:51 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 30335449]
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: Starting performScheduleFunction of DFM Poller Wed Sep 07 06:43:05 CDT 2011
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: Result from isDFMDataRefreshRequired(): False
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: Result from TopoClientFinder.anyN_HopViewOpen(): False(checking topo necessary)
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: Result from TopoClientFinder.anyTopoClientOpen(): false
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: Not executing DFMPoller because neither Topology clients nor N Hop clients are open
2011/09/07 06:43:05 DFMPoller ani MESSAGE DFMPollerTimeBaseImpl: ....so not updating Poll Time, as poll didnt actually happen
Here is the PDShow:
Process= UPMDbEngine
State  = Program started - No mgt msgs received
Pid    = 2564
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:15:35 PM
Stop   = Not applicable
Core   = Not applicable
Info   = Application started by administrator request.
Process= UPMDbMonitor
State  = Running normally
Pid    = 3004
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:15:39 PM
Info   = DbMonitor Running Normally.
Process= Tomcat
Pid    = 3020
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:15:42 PM
Process= TomcatMonitor
Pid    = 2920
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:15:46 PM
Info   = Tomcat Server up
Process= Apache
Pid    = 2304
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:16:43 PM
Process= RMEDbEngine
Pid    = 5136
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:16:45 PM
Process= Proxy
Pid    = 5264
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:16:49 PM
Info   = Server started by admin request
Process= ProcSysBus
Pid    = 5272
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:16:52 PM
Process= OpsxmlDbEngine
Pid    = 5324
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:16:58 PM
Process= OpsXMLRuntime
Pid    = 5392
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:17:04 PM
Process= CWAPublisher
State  = Administrator has shut down this server
Pid    = 0
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:17:08 PM
Stop   = 9/6/2011 1:22:18 PM
Process= NameServer
Pid    = 5468
RC     = 0
Signo  = 0
Process= NameServiceMonitor
Pid    = 5900
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:17:12 PM
Info   = NameServer is fully up now !
Process= EDS
Pid    = 6080
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:17:16 PM
Info   = Initialization complete
Process= LicenseServer
Pid    = 6164
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:18:37 PM
Process= INVDbEngine
Pid    = 6900
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:18:39 PM
Process= FHPurgeTask
State  = Transient terminated
Pid    = 0
RC     = 0
Signo  = 0
Start  = 9/7/2011 12:00:00 AM
Stop   = 9/7/2011 12:00:01 AM
Info   = DPS Task FHPurgeTask completed at Wed Sep 07 00:00:01 CDT 2011. For status check Job Browser UI.
Process= FHDbEngine
Pid    = 6932
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:18:45 PM
Process= ESS
Pid    = 6856
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:18:49 PM
Process= EssMonitor
Pid    = 6608
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:18:53 PM
Info   = ESS is fully up now !
Process= EventFramework
Pid    = 6224
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:00 PM
Process= PMServer
Pid    = 1172
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:01 PM
Info   = PMServer is up and running
Process= SyslogCollector
Pid    = 7408
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:05 PM
Process= EPMDbEngine
Pid    = 7416
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:07 PM
Process= EPMServer
Pid    = 7760
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:11 PM
Info   = EPMServer is up and running
Process= FHServer
Pid    = 8048
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:15 PM
Info   = FHServer started.
Process= diskWatcher
Pid    = 8076
RC     = 0
Signo  = 0
Info   = diskWatcher initialized OK.
Process= DFMMultiProcLogger
Pid    = 8084
RC     = 0
Signo  = 0
Process= DFMLogServer
Pid    = 8116
RC     = 0
Signo  = 0
Process= DFMCTMStartup
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 9/6/2011 1:22:19 PM
Process= DfmBroker
Pid    = 7548
RC     = 0
Signo  = 0
Process= DfmServer
Pid    = 7284
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:19 PM
Info   = DfmServer initialized OK.
Process= DfmServer1
Pid    = 7840
RC     = 0
Signo  = 0
Info   = DfmServer1 initialized OK.
Process= DCRDevicePoll
State  = Never started
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Info   = Not applicable,
Process= CSSCPServer
Pid    = 7880
RC     = 0
Signo  = 0
Process= CSRegistryServer
Pid    = 7044
RC     = 0
Signo  = 0
Info   = CSRegistryServer is running in other process
Process= CSDiscovery
Pid    = 0
RC     = 0
Signo  = 0
Start  = 9/7/2011 1:00:04 AM
Stop   = 9/7/2011 3:23:08 AM
Process= CmfDbEngine
Pid    = 7040
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:21 PM
Process= CmfDbMonitor
Pid    = 8744
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:25 PM
Process= DCRServer
Pid    = 8852
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:19:26 PM
Info   = DCRServer is up and running
Process= CMFOGSServer
Pid    = 7692
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:10 PM
Process= CampusOGSServer
Pid    = 2172
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:14 PM
Process= EssentialsDM
Pid    = 9076
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:15 PM
Info   = RME Device Management started.
Process= ConfigMgmtServer
Pid    = 8872
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:20 PM
Process= ICServer
Pid    = 9256
RC     = 0
Signo  = 0
Info   = ICServer started.
Process= RMEOGSServer
Pid    = 9264
RC     = 0
Signo  = 0
Process= PMCOGSServer
Pid    = 9624
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:24 PM
Process= TISServer
Pid    = 9672
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:25 PM
Process= DFMOGSServer
Pid    = 10208
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:29 PM
Process= InventoryCollector
Pid    = 9288
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:33 PM
Info   = InventoryCollector is up and running
Process= Interactor
Pid    = 10496
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:37 PM
Process= InventoryCollector1
Pid    = 10504
RC     = 0
Signo  = 0
Process= Interactor1
Pid    = 11004
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:20:41 PM
Process= NOSServer
Pid    = 11012
RC     = 0
Signo  = 0
Info   = NOSServer is up and running
Process= PTMServer
Pid    = 11024
RC     = 0
Signo  = 0
Info   = Started Successfully
Process= UPMProcess
Pid    = 0
RC     = 1
Signo  = 0
Info   = UPMProcess started successfully.
Process= EDS-GCF
Pid    = 11176
RC     = 0
Signo  = 0
Info   = GCF Initialization complete at Tue Sep 06 13:21:51 CDT 2011
Process= jrm
Pid    = 11208
RC     = 0
Signo  = 0
Process= 1012
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1425
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 2072
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 3886
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CTMJrmServer
Pid    = 12068
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:22:00 PM
Info   = CTMJrmServer started.
Process= ChangeAudit
Pid    = 11680
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:22:10 PM
Process= SyslogAnalyzer
Pid    = 11504
RC     = 0
Signo  = 0
Process= DataPurge
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 9/6/2011 1:22:49 PM
Info   = DataPurge initialization completed at Tue Sep 06 13:22:49 CDT 2011.
Process= ANIDbEngine
Pid    = 5384
RC     = 0
Signo  = 0
Start  = N/A
Info   = Service was already running
Process= ANIServer
State  = Running with busy flag set
Pid    = 6708
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:22:14 PM
Info   = ANIServer started.
Process= UTMajorAcquisition
Pid    = 0
RC     = 0
Signo  = 0
Start  = 9/6/2011 6:00:00 PM
Stop   = 9/7/2011 3:31:19 AM
Process= MACUHIC
Pid    = 6280
RC     = 0
Signo  = 0
Start  = 9/6/2011 1:22:18 PM
Info   = Started.
Process= UTLITE
Pid    = 6344
RC     = 0
Signo  = 0
Info   = Started.
Process= UTManager
Pid    = 6620
RC     = 0
Signo  = 0
Info   = Started.
Process= VNMServer
Pid    = 11672
RC     = 0
Signo  = 0
Process= WlseUHIC
Pid    = 11768
RC     = 0
Signo  = 0
Info   = Started.
Process= AdapterServer1
Pid    = 10852
RC     = 0
Signo  = 0
Pid    = 844
RC     = 0
Signo  = 0
