Changing Duplex-Mode and Port-Speed via SNMP on IOS Routers (870/1800)?
CSCO10595164
Hi!
I´m searching for a  way to change duplex-mode and Port-Speed on IOS Routers 871 and 1811 via SNMP. I have OIDs for read-only-access but i did not succeed in  setting the values. Do you know the right way/OID?
Thanks a lot for your help!
Leo Laohoo
I'm no SNMP expert.  Instead I use a proggie called "Cisco SNMP Tool" by BillyTheKid.
I use this proggie to upload the config I want to the appliance using SNMP.
