I've been unable to get netflow working on a Cisco 3750x with a C3KX-SM-10G module. I went over the configurations with Cisco TAC and we verified they are correct. However, Cisco states that I have to use the tenGigabitEthernet interfaces. Problem is that we are all still running 1GB.
Is there a way to get this to work with gi1/1/2 and gi1/1/4 instead of using te1/1/1 and te1/1/2?
Here are my configs:
flow record NetFlow
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect interface input snmp
collect interface output snmp
collect counter bytes
collect counter packets
flow exporter Netflow-to-Cascade
destination 167.155.16.186
source Vlan1128
transport udp 2055
flow monitor NetFlow
record NetFlow
cache timeout inactive 10
cache timeout active 5
interface GigabitEthernet1/1/2
description Connection to genn2blab-l2s05 gi1/0/4
switchport trunk allowed vlan 1128,1130
switchport mode trunk
switchport nonegotiate
ip flow ingress
ip flow monitor NetFlow layer2-switched input
ip flow monitor NetFlow layer2-switched output
