Can not SSH into specific LAN IP via FPR1010 WAN
TheGoob
Hello
FPR1010 - x.x.x.182
192.168.5.9 LAN Device w/ SSH Port 23 (it seems if I use 22 it goes to FPR1010 directly.)
I made a NAT;   inside_2   192.168.5.9    any   ssh-23   any  outside   any   ssh-23   any (Manual NAT, Dynamic, above inside_2)
I made ACL;     outside   any   any   inside_2   192.168.5.9    ssh-23   any   any   any
Does not work... Just times out. But, on the LAN, I can connect so SSH-23 is indeed active. Any help!
30 Replies 30
It has to be something incoming... Those hosts can access Internet just fine so it is not a routing issue.
Does an INNER Network need special NAT rules aside from the specific SSH NAT rule? Like, it just is not making sense.
