Can not suppress Alarm on Prime Infrastructure 3.3...
SIMMN
I inherited a "brand new" PI, running version 3.3.0.0.342. It has Cisco WLC5508 added and all the APs are showing up. However one confusing thing: I can not get rid of the link down critical alarms, such as
Port '4' (Description: 'Not Available') is down on device
'192.168.192.1'.
There are only two ports on the WLC5508 in use and others are not plugged in...
Under WLC web UI, I did disable the trap control for "Link (Port) Up/Down"...
I also created a alarm policy to suppress the Link down alarm on WLC...
None of these helped as the same alarms come up pretty quick after I manually clear them...
Inside the alarm message, the general section:
Failure Source
192.168.192.1:wlc-lab-1:e0:5f:b9:10:10:11
Acknowledged
No
Category
Controller
Created
April 13, 2018, 6:14:30 PM
Modified
May 3, 2018, 3:45:46 PM
Generated By
NMS
Severity
Critical
Previous Severity
Cleared
Advice? BTW, if NMS generates the alarm, does it mean PI itself did that?
marce1000
 - Check this thread; the idea is to disable the unused  ports on the controller :
 https://supportforums.cisco.com/t5/getting-started-with-wireless/prime-wlc-interfaces-down/td-p/2899891
M.
marce1000
M.
It works but still feel that is a bad workaround...
