Can't ping between PC in different networks on the same router
developemmanuel
Networks:
  • Network 1 (Port - Gi0/0): 192.168.0.0/24
  • Network 2 (Port - Gi0/1): 10.0.0.0/16
Issue
  • When I ping the default gateway per each port it works (Gi0/0: 192.168.0.1, Gi0/1: 10.0.0.1), but when I try to ping some specific device there's a request timeout
  • I'm currently using a Cisco Router 1941
  • In the simulator works fine, but in my try between my PCs the ping doesn't work, which means at some point that there's not communication between the PC connected to the same router in different networks
5 Replies 5
@developemmanuel can you share brief diagram how you connected to devices and port numbers
Good luck
KB
Joseph W. Doherty
It's a bit unclear exactly what's pinging what in your topology.
Basically, are you sure all hosts have a gateway to their network's router interface?  If not, is proxy ARP enabled on the router interfaces?
Edson A. Hernandez
Firstly, verify if you have the correct gateway configured on each PC.
There are other things you should consider. Can you please share the output of the following command: 'show ip route'
Sorry for not answering, but I've already solved it. It was the VPN that was active in my PC. Thank you for your support
developemmanuel
Sorry and thanks for the support but the issue was an active VPN in my network. 🫶
