Can't ping Outside or DMZ using ASA 8.4
sbaishakhi
Hello all,
Thanks for all of your help.
Ok, I have a ASA 8.4 firewall that I have been working on so long.
It was a hassle to configure the object group and nat for 8.4.
So, I put two host in both side of ASA to test pinging but I can not ping the outside or the DMZ.
I attached my nat config.
Thanks.
Shefat
sbaishakhi
Looks like I can ping from the firewall to outside interface and the outside host.
But I can not ping this two places from the inside host. But I pin ping the firewall from the inside host.
It is not going through the firewall ..... very confusing.
Same with DMZ.
Shefat.
