Cannot load MIB on HUM
sinan.tekincan
Hi all,
I am trying to load CISCO-VOICE-DIAL-CONTROL-MIB to HUM. Bu I cannot load two of the dependencies: DIAL-CONTROL-MIB and INT-SERV-MIB.
Although all the dependencies of these two mibs are laoded, when I try to load these two mibs, I get the error "Unable to load the MIB file. Either you are trying to load an invalid MIB file  or the dependent MIB files are not available in the path."
What can be the cause of this problem?
Thanks...
Joe Clarke
Exactly what version of HUM do you have?
I have the HUM version 1.2 bundled in LMS 3.2.
Don't try loading all of the dependencies.  Just make sure they are all in the mibs directory.  Then, replace your CISCO-VOICE-DIAL-CONTROL-MIB.my file with this one.  Then just try loading the CISCO-VOICE-DIAL-CONTROL-MIB.my directly.
Thank you very much,
This new mib file loaded successfully.
