Cannot Reload Cisco ASR920 using SNMP
All,
I can successfully reload all my Cisco 3650/2960 switches using SNMP, but I cannot use the same method with the ASR920
snmpset -c rwcomm -v 2c x.x.x.x .1.3.6.1.4.1.9.2.9.9.0 i 2
On the ASR920, I get a "Reason: notWritable (That object does not support modification)" error.
Is this not supported on the ASR920? If not, any other way or OID?
PS: I do have "snmp-server system-shutdown" configured on the routers.
Mark Elsen
 - Perhaps software  related or a  bug. Are you running a recent software release ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
<--Deleted-->
Doesn't look like a bug. I tried the oldest image I had (asr920-universalk9_npe.03.16.06.S.155-3.S6-ext.bin) and the newest image I have (asr920-universalk9_npe.16.09.02.SPA.bin) and found the same results.
It looks like the ASR920 series doesn't support this (Strangely, it still supports the global config)
