Netshow in Cisco Prime 3.2 (express plus)
Hello all,
LMS 4.1 had a lovely feature (netshow commands), that helped us perform daily routine tasks. Currently we are running PI 3.2 (express plus). Is there a similar tool in PI 3.2.
We want to run a simple command daily on our routers, to check some routing issues. Is there a way to accomplish this via PI?
Thank you in advance,
Katerina
2 Accepted Solutions
what you can use as a workaround....
create a config template and use the following (as an example)...
do show interface status
afterwards deploy the template and check the results in the job details
lsosa_hnywl
You could also use the following format in a configuration CLI template, for example:
#MODE_ENABLE
show command(s) here
#MODE_END_ENABLE
I have tested this and works fine in our Prime Infrastructure 3.4 server..
Regards..
6 Replies 6
marce1000
https://supportforums.cisco.com/t5/network-management/netshow-and-prime-infrastructure-2-2/td-p/2652037
             (Afraid there's still no netshow)
M.
Thank you for the reply!
It is such a pity that the best features of LMS are not included in PI!
Great idea!
Thank you very much! At least I can do something with the product!
lsosa_hnywl
#MODE_ENABLE
#MODE_END_ENABLE
Regards..
Hi!
Thank you for the info. It works perfectly
Thanks!
