Cannot telnet to devices from topology view
Dear fellows,
I am unable to telnet to any device from CM topology view. I ran device troubleshooting on one of the switches and noticed the below which I thought could be related to my problem:
Generic OnLine Diagnostics (Generic OnLine Diagnostics details not available for the selected device.)
TELNET: Failed to establish TELNET connection to 192.168.127.48 -Cause: Authentication failed on device 3 times. Could not detect SSH protocols running on the device
All devices use telnet for management while ssh being disabled.
How can I solve my problem? Any thoughts are truely appreciated.
Thanks all.
Moath Rawashdeh
Ahh, forget to mention the version, I'm using LMS 3.2.1 with CM 5.2.2.
Thanks.
CiscoWorks will first try the telnet
Kindly first run the Credentials Verification job for the telnet protocol for same device from
Inventory > Job Browsers: Device Credential Verification > create new job for the telnet for the device and share the output.
please go to the Control Panel -> Java -> Advanced and enable to java  console.  Perform the topology load and telnet and then send the results from the java console.  Also the version of java loaded on your PC.
Many Thanks,
Gaganjeet
Thanks Gaganjeet,
The output of the Java console is :
JRE Version:1.6.0_22
Recommended JRE Version:1.6.0_22
Endorsed dir is:C:\Program Files (x86)\Java\jre6\lib\endorsed
EXT DIR:C:\Program Files (x86)\Java\jre6\lib\endorsed
getApplicationParameters...
initializeProperties...
initializeSwing...
ClientModule.installAllModules...
performAniLogin...
Session id is alpha-numeric, Exception:For input string: "C273BF25E45A20EBCA21EC8604E49D6A"
_Orb=org.jacorb.orb.ORB@42a818
2011/09/05 13:56:53 MESSAGE AniEventMgr: Event Manager has been enabled
1315223814015 September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace PBPB*****FilteredEventConsumer::realctor() servicename= EC_network-lms_AniCoreStates_1315223813921.ec.0,  newsname=EC_network-lms_AniCoreStates_1315223813921, props= {ORBInitRef.NameService=http://network-lms:1741/CSCOcm/classpath/NS_Ref, org.omg.PortableInterceptor.ORBInitializerClass.bidir_init=org.jacorb.orb.giop.BiDirConnectionInitializer, AniEvents.server=network-lms, vbroker.agent.port=42342, org.omg.CORBA.ORBSingletonClass=org.jacorb.orb.ORBSingleton, AniEvents.MaxInitWaitTime=30, AniEvents=on, AniEvents.EventSourceThread=off, jacorb.implname=StandardAniImplName, vbroker.agent.addr=network-lms, org.omg.CORBA.ORBClass=org.jacorb.orb.ORB}
1315223814015 September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: init_event: EC_network-lms_AniCoreStates_1315223813921.ec.0
1315223814046 September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilterCallback created: EC_network-lms_AniCoreStates_1315223813921.ec.0
September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms Debug ByteToObject: constructed
1315223814062 September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilterCallback: run: EC_network-lms_AniCoreStates_1315223813921.ec.0
Trying to get the already bounded object
FilteredEventConsumer: init_event : Successfully created consumerconnector for EC_network-lms_AniCoreStates_1315223813921.ec.0
1315223814250 September 5, 2011 1:56:54 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
2011/09/05 13:56:57 MESSAGE AniEventMgr: Event Manager has been enabled
1315223817531 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace PBPB*****FilteredEventConsumer::realctor() servicename= EC_network-lms_AniCoreStates_1315223817531.ec.1,  newsname=EC_network-lms_AniCoreStates_1315223817531, props= {ORBInitRef.NameService=http://network-lms:1741/CSCOcm/classpath/NS_Ref, org.omg.PortableInterceptor.ORBInitializerClass.bidir_init=org.jacorb.orb.giop.BiDirConnectionInitializer, AniEvents.server=network-lms, vbroker.agent.port=42342, org.omg.CORBA.ORBSingletonClass=org.jacorb.orb.ORBSingleton, AniEvents.MaxInitWaitTime=30, AniEvents=on, AniEvents.EventSourceThread=off, jacorb.implname=StandardAniImplName, vbroker.agent.addr=network-lms, org.omg.CORBA.ORBClass=org.jacorb.orb.ORB}
1315223817546 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: init_event: EC_network-lms_AniCoreStates_1315223817531.ec.1
1315223817546 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilterCallback created: EC_network-lms_AniCoreStates_1315223817531.ec.1
September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms Debug ByteToObject: constructed
1315223817562 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilterCallback: run: EC_network-lms_AniCoreStates_1315223817531.ec.1
1315223817640 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
FilteredEventConsumer: init_event : Successfully created consumerconnector for EC_network-lms_AniCoreStates_1315223817531.ec.1
1315223817687 September 5, 2011 1:56:57 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223817531.ec.1, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818125 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818265 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818296 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818312 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818359 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
1315223818375 September 5, 2011 1:56:58 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
In DeviceManager, subscribed for alert events
SSH Property File: C:\Documents and Settings\Administrator\campusmgr.properties
Argument for launching the layer2 Map.... appletParam_loadLayer2Map:null
1315223823187 September 5, 2011 1:57:03 PM EC_network-lms_AniCoreStates_1315223813921 network-lms DistMethodTrace FilteredEventConsumer: setClassInstance : EC_network-lms_AniCoreStates_1315223813921.ec.0, filtobj=com.cisco.nm.ani.share.events.AniEventFilter, init-state=true
2011/09/05 13:57:07 ERROR ClientUICache: Image not found(1), fileName = highseverity_8.gif
The device credentials verification job was successful as can be seen from the below.
We are running version 1.6.0_22 of java.
Thanks.
