cant connect to ssh with username Admin1
Verrita
I'm doing an activity and for some reason I cant connect with ssh to a router with the username Admin1. Every time i connect I recieve a login error like if the password I entered was wrong. I tried creating a different username and ssh worked normally, tried deleting Admin1 and recreating him but still no luck. Seems like there is a problem directly with Admin1. Any suggestions how to fix the issue?
8 Replies 8
I dont fully sure but admin I think one of keyword using with ssh in OS' this make using username admin impossible.
MHM
But the username I'm using is "Admin1" so it should not be a keyword anymore or am I wrong?
To test what I suspect of' try do telnet and see if you can access.
As I mention some OS ssh is sensitive to admin word.
MHM
Would you do these things:
login to the router
configure user Admin1
logout of router
attempt to login using Admin1
assuming that it fails login with ID that does work
use command show run | include user and post the output
Rick
Sorry for the late answer. The output seems normal, i get the username and the encrypted password
Is this device using an authentication server or is it using locally configured IDs? It would be helpful if we could see the current running config (obscuring sensitive information such as passwords, Public IPs, etc). If you do not want to post the complete config would you post the output of the command show run | sec aaa
Rick
Can you share the exact error message you are receiving?
Regards, LG
*** Please Rate All Helpful Responses ***
The error message I receive is
% Login invalid
