Cant ping from switch to switch PCs
wildhacker741
As u can see on the picture itself it has 2 switch. So for Switch 1 the one above the switch are able to ping different department PCs. And the other switch the one below are not allowed to ping other PC branches. Both of these switch i've done trunking F0/1 and G0/1. And also i believe that i had already checked IP address on the PCs as wells.
Now my main problem is Switch 2 the one bottom. I cant seems to ping this PC to other branch PC.
The only thing i done is trunking on both switch and subinterfaces on router thats all. Is there anything i need to configure?
Diana Karolina Rojas
In order for a switch to ping other devices you have to configure and SVI (layer 3 interface vlan) with an IP address, it will we used as Source IP address of the ping packets you generate from the switch, also you need to configure a default gateway for the switch , this will help you to reach devices in other subnetworks or vlans. Do you have a management vlan in your simulation?
Please do not forget to rate useful post.
Best regards,
Yes
I can't understand your response, did you resolve the problem?
Please do not forget to rate useful post, your rating motivate us to continuing participation in the community.
Best Regards,
