Captive portal on cisco wlc 3504
sathyajith
Hi Guys,
I am trying to create captive portal on cisco wlc 3504 where the guest users can login with the username and password. Given to them.
Can someone guide me though the same?
Thank you..
balaji.bandi
WLC alone can not do this you need ISE or any other external source to get process this request.
i found some simple script if you looking to test:
https://github.com/stuartst/cisco-wlc-captive-portal
BB
