CAT9K_IOSXE Guestshell ZTP - Python / cmd can not execute in non-interactive context
cisco.13
I am trying to install a cat9k_iosxe.16.06.03.SPA.bin image with guestshell (ZTP - Python),
I have this message:
"% Interactive command can not execute in non-interactive context"
! here is the command:
install_cmd = "request platform software package install switch all flash: cat9k_iosxe.16.06.03.SPA.bin auto-copy"
cli.executep (install_cmd)
Nota: The execution of the command in privileged EXEC mode is correctly executed and without confirmation message (non interactive)
Thank you for your help.
Joe Clarke
Even if the command does not prompt, it may be marked interactive.  I'd generally consider that a bug.  To workaround this, you can use EEM to wrap the command:
event manager applet upgrade
 event none maxrun 300
 action 1.0 cli command "enable"
 action 2.0 cli command "request platform software package install switch all flash: cat9k_iosxe.16.06.03.SPA.bin auto-copy"
Then:
install_cmd = "event manager run upgrade"
5 Replies 5
Joe Clarke
Then:
Hi, it works with EEM, thank you Joe
Nota : install_cmd = ....switch all FILE flash:......
Could you please share some code examples how to use the event manager in this case?
The example here already is an example using EEM (the EEM applet).  I'm not sure what you're looking for specifically.
Joe's example shows how to use eem
python :
eem = '''event manager applet upgrade
action 2.0 cli command "request platform software package install switch all file flash: cat9k_iosxe.16.06.03.SPA.bin auto-copy" '''
cli.configurep(eem)
