Catalyst Script to Extract Flow Data
pandreozzi
Frequent Visitor
Frequent Visitor
My question is around extracting flow data from some legacy Cisco 3750 and 3550 switches with layer 3 images.
Netflow is not supported on these devices and I don't think you can create an event option that triggers logging to send this data to a syslog server.
So my question is this.
Can a script be created that runs in the background that will collect this info and forward to a syslog server remotely configured.
All responses are greatly appreciated.
Paul
17 Replies 17
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
config t
Logging buffered debug
logging buffered xxxx (deprends the value you need)
end
test and advise.
Note : this will have high impact on the device. so keep monitor
BB
logging buffered debug
logging buffered 16000
... don't run it for long at that log level
As for your solution, agreed you are going get some useful info out of it, but these hits are all stateless, you will need some pivot-table-fu to aggregate them back into flows. Even then, you will be missing useful datapoints such as packet sizes and therefore total data transferred.
cheers,
Seb.
pandreozzi
Frequent Visitor
Frequent Visitor
Thanks Seb
