CCNA Exam
jgse19811
Hi All.
Hoping that you can help.
CCNA exam, on the CLI, I am able to use short hand cmds i.e. conf t, copy run start, sh ip int brief or do the cmds have to be full i.e configure terminal etc?
When saving the config can use wr or does it have to be copy run start?
Stay Safe.
Yours in Prosperity,
Jonathan Edwards
Martin L
they latest info I got from CLN is that they are ok to use and are working. They were ok when I took exam long time ago;  But you should be prepared to type in full command just in case.  In my case, I think wr did not work, I had to use copy run start.  And other time, copy run did not work and I assumed was not needed (they did not ask for it).
Note: tab and ? also work.
go to CLN study group, search and/or ask your question there
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
Regards, ML
**Please Rate All Helpful Responses **
Note: not all commands are available in the Sim since the exam interface is not real IOS. so, be prepared to use other commands to get info; aka know and use different methods of doing same things.
