CCP doesn't show ip helper-address
joe-hummel
I am running CCP 2.1 on both a Vista and Server 2008 machine. I am connected to an 1841 router. If I telnet into router, and show run, it says I have an ip helper-address. If I open CCP and view that same interface, it doesn't show an ip helper-address. If I then click OK, it wants to send a command to the router to remove the ip helper-address. Any ideas would be appreciated.
shmcguir
Hi Joe,
I'll see if I can check this out in our lab. Can you send me the show version of the 1841 device, and also let me know the configuration you have on the interface with the ip helper address please?
Best regards,
Shane
Version is 12.4
Int fa0/0 ip address 10.188.110.1 / 24 lan with ip helper 192.168.188.201
No other changes on that int from default.
Joe
Hi Joe,
  Please pickup the latest CCP version (v2.5 posted on 29th June 2011). Let me know if the problem is resolved. CCP supports configuration of single helper address. If multiple addresses are configured, then they are read in, but shall not be editable.
Chaitra
