06-21-2006 01:45 AM
We need to trace all the switches and routers connection in the office and will require the protocol cdp enabled.
Please what are the advantages/disadvantages and Vulnerability of enabling this protocol?
What is the best practice?
Solved! Go to Solution.
06-21-2006 02:47 AM
Do you have a CCO login?
If so:
http://www.cisco.com/en/US/customer/tech/tk962/technologies_tech_note09186a00801aa000.shtml
Otherwise:
http://www.google.com.au/search?hl=en&q=cdp+protocol+cisco&meta=
06-21-2006 02:41 AM
Best practice is disable CDP on any interfaces accessible from outside your network.
CDP can be used by intruders to determine:
Device type
IOS version
IP address
And more....
With this information in hand a network can be compromised quite easily, especially if out-dated IOS versions are being used.
06-21-2006 02:42 AM
Is there any documentation I can read further on this as I need to convince my boss.
06-21-2006 02:47 AM
If so:
Otherwise:
06-21-2006 07:37 AM
You can disable cdp globally using no cdp run
or disable cdp on certain interfaces
config t
int x/x
no cdp enable
this way you can turn it off with points which might have external network connections such as border routers.
Peter
