Changing banners with NetConfig
raymond.lucas
I am trying to create an IOS user template with NetConfig. I am importing the config from a file.
If the config contains a "banner exec", any job pushing this out fails with a "CLI Output - FAILURE" message.
Have others experienced this problem? Have others worked around this problem?
5 Replies 5
steve.busby
Level 5
Level 5
If you're creating a Template, ensure your command is as follows:
banner exec "Sample Text"
This works on a W2K/RME 3.5/IDU 9.0 system. I used the existing banner template, plus I created my own using the command above. Both worked flawlessly.
What OS, RME, IDU versions are you running?
I am just importing the configuration from a text file. The text file can be successfully tftp'ed to the running config of the device so the commands are right.
We are using SunOS 5.8/RME 3.5/IDU 11. I have tried it on earlier IDU's with the same result.
Using the banner template does work for me, but I can't save that to use later which is what I want.
Thanks for your time.
Hi there
I've had the exact same problem awhile ago. I also tried everything: installed newer IDU's , changed the banner format. No luck. Reading your message confirms that it might be a RME bug.
I will be watching this space for any news.
Raymond,
I'd be interested in seeing all the lines for a particular failed device, can you post those? Also, what type of device(s) are you trying to update?
Steve
The devices are a mix of 7200 on 12.1E, 3600 and 2600 on late 12.2T. IP Plus 3DES images.
Here is a (very simplified) example of the sort of config I'm trying to push (with the === bits :)
ntp server 1.1.1.1
banner exec "
| Test |
no ip http server
This is in a file on the CW server. I create a User Template (Type=IOS, mode=Config) and import from a file. Once saved, I create a job. Whenever displayed, the config looks correct. When the job finishes with Status: Failed, the only output is:
ntp server 1.1.1.1
test(config)#
PARTIALFAILURE
Via experiment, I know it is only the banner command that causes a problem. The transport is configured to use SSH, Telnet, TFTP. RCP is disabled. In this example telnet is actually used.
A tcpdump of the traffic shows the ntp command sent and responded to fine, the banner exec " part of the command is sent, the router responds as you would expect with:
Enter TEXT message. End with the character '"'.
The server then waits just over a minute and sends a logout command.
When you do a job using the provided Banner template bu contrast, the banner is sent as one long string. Which works fine.
So I guess it's different control characters being used to indicate the CR between the two methods that lets one work and the other not. Sigh.
And yes, I would open a TAC case, but we don't have cover for our Cisco software unfortunately.
Whew... that turned out quite long!
