Changing Duplex-Mode and Port-Speed with SNMP on IOS-Switches (4000/6500)?
r-warnecke
As we have to change from CAT-OS to IOS on our switches I´m searching for a way to alter duplex-mode and Port-Speed on Catalyst 4000/6500-Switches via SNMP. I have OIDs for read-only-access but i did not succeed in setting the values. Do you know the right way/OID?
Thanks a lot for your help!
Ralf
5 Replies 5
b.hsu
Level 5
Level 5
Try this command
snmpwalk -c public ifMauDefaultType.5.1
MAU-MIB::ifMauDefaultType.5.1 = OID: SNMPv2-SMI::zeroDotZero
Set the ifMauDefaultType so it is not zeroDotZero then you should be able to set the ifMauAutoNegAdminStatus. Hope this helps.
f.joern
Dear R-Warnecke,
I'm very interested in even "reading" the duplex-mode of my switch-ports. I tried
snmpwalk berl-sw01-1 xxxxxxx .1.3.6.1.2.1.26, but i get no reply, probably the switch doesn't support the "mau-mib"? snmpwalk with other oids works fine.
We use IOS-Switches catalyst 6000, 2950 with ios V.12.1...
Do You have an idea how to read the duplex-mode-settings?
best regards
Frank
OSRAM, Berlin
prakashrj
Use the following oids to set port speed and duplex settings.
CISCO-STACK-MIB::portAdminSpeed
CISCO-STACK-MIB::portDuplex
Prakash.
prakashrj
Prakash.
Hello Prakash,
I wish you a happy new year.
Thanks for your advice, but unfortunately it seems that most of my switches doesn't support this mib.
Frank.
