Routers and Switch Conf for Network Management
Mansoor Hafeez
Following are my Router and Switch Configuration
Router A
interface Fastethernet0/0
no ip address
duplex auto
speed auto
interface Fastethernet0/0.1
encapsulation dot1q 2
ip address 192.168.121.249 255.255.255.248
interface Fastethernet0/0.2
encapsulation dot1q 3
ip address 192.168.99.249 255.255.255.248
interface Fastethernet0/0.3
encapsulation dot1q 4
ip address 192.168.4.137 255.255.255.248
Switch A
interface fa0/12
switchport mode trunk
interface vlan4
ip address 192.168.4.138 255.255.255.248
Now the problem is with the ip address of Switch. Somehow with vlan4 it is not establishing a connection with Router. If i change the interface on Switch from vlan4 to its default of vlan1 than it works fine and also communicates with my CiscoWorks at the other side of Router.
My actual Network Management VLAN is 4. Can someone help me in this regard.
With Best Regards
Mansoor
Hi Mansoor,
It looks like you have forgotten to change the native vlan from its default value of vlan 1 to vlan 4
The native VLAN is used for untagged traffic when the port is in 802.1Q trunking mode. While configuring 802.1Q trunking, it is very important to keep in mind that the native VLAN must be configured the same on each side of the trunk link
Command to use for Router
int fa0/0.3
encapsulation dot1Q 4 native
Command to use for switch
int fa0/12
switchport trunk native vlan 4
To check the settings use the following command on switch.
show int fastEthernet 0/12 switchport
Let us know if that sorts out your problem
Sarb
Patrick Laidlaw
Level 4
Level 4
Mansoor,
From what I can see your configs look right.
1. Your not using vlan 1 for anything
2. 2950's depending on which version only support dot1q and you have do1q 4 for vlan 4 so thats right.
3. Both ips are in the same bit boundary.
Here are a couple of things you can try shut down your interfaces and bring them back up. It'll take about 45 seconds for them to come up then try pinging from the switch to the router a couple of times, and vica versa. Be patient might take a moment longer than you expect.
Two for S&G try shutting interface vlan 1 down on the switch. I know it shouldn't do anything but It seems like I remember I've had problems before with both of them up.
Three make sure the vlans are setup in your vlan database. To verify execute the following command
"sh vlan brief"
If your vlans are missing go and add them with the following from the privledge exec mode.
switch#vlan database
switch(vlan)# vlan 4 name VLAN-4
switch(vlan)# vlan 3 name VLAN-3
switch(vlan)# vlan 2 name VLAN-2
switch(vlan)# exit
Hope that Might help
Patrick
Hi Mansoor,
int fa0/0.3
int fa0/12
Sarb
