Changing Interface Description (Bulk)
galamayur
Level 3
Level 3
I want to change interface description for more then 2500 ports for my Cisco devices.
I am hunting for a SNMP based tool which can solve my purpose.
Which can list all the ports of the devices along with the interface description & can be edited through the GUI.
So that I do not need to login into each device via telnet & go on to every interface to change the description.
Thanks in advance.
n.bowbridge
Level 4
Level 4
It's not an SNMP tool but Kiwi CatTools can automatically login to your switches and perform scripted updates. Pretty easy to setup as well. From memory $100 US will get you the appropriate license.
http://www.kiwisyslog.com/cattools-info.php
