Changing the Severity Level of a System Log Message
lwallimann
Hello together
knows someone how I can change the severity level of a System log message on a Catalyst 3750 ?
I have seen a command for the 6500 "logging message message_ID level severity_level" but I din'd find one for the 3750.
thanks a lot
Regards Lars
thanks a lot
this link describes how i can set the severity level to the consol or something else. by default all message from this severity and lower will be send and so to many message are generated if I only change the severity in my case. I will change the severity of only one message...
regards lars
I am not sure whether the future you are asking is supported but i am sure the same kinda CLI is available with security appliance box CLI.
Its been discussed under this link ,though i havent tried the same you can refer and try out the same.
http://cisco.com/en/US/products/ps6120/products_system_message_guide_chapter09186a00805452cf.html#wp1124416
regds
thans a lot
it seems that the catalyst 3750 dose not support this feature.... :-(
