Check traffic between VLANs with Prime, is it possible?
schulcz
Hi Guys!
We have Catalyst 4500X pair as core switches, and use many VLANs and VRFs on it. All VLANs have a default gw on 4500X, and we use transit VLANs between 4500X and firewall (1 transit per VRF). Traffic between VRFs is filtered on firewall.
We use Cisco Prime also.
I'm wondering about is it possible to check the amount of traffic between VLANs in a single VRF with PI? Eg. there are VLAN 10, 20 and 30 which are user VLANs and there is a VLAN 100 which is a server VLAN, and I would like to check the amount of traffic between server and user networks.
Thanks!
schulcz
Is there a way to check the amount of current traffic historically? I'm not interested about the type of traffic, only need to know the amount (because of a planning of separation).
