07-07-2022 02:36 AM
Cisco Integrated Management Controller Version : 4.1(3h)
We are trying to get a properly functioning SSL connection for the web interface on the CIMC. We succeeded in uploading the private key, and corresponding end entity certificate. After activating those, they are also properly used for the connection. But still we cannot validate the connection, because the certificate is not signed by a Root CA, but one CA below it. To make chain validation work, the intermediate certificate of the CA needs to be added to the chain the CIMC offers.
I was unable to find a way to upload such a certificate, or any documentation of such a process.
So, how do I add an intermediate certificate to my CIMC for SSL connections?
07-07-2022 03:51 AM
If yu like you can download CA cert from your browser :
follow below guide :
=====️ Preenayamo Vasudevam ️=====
07-08-2022 12:17 AM
I read that one, but it does not contain any clues ON uploading CA / Intermediate certificates.
07-08-2022 03:40 AM
is this Local CA ?
07-08-2022 04:35 AM
Local as in Our company yes. So the chain to validate the certificate chain is:
The CIMC needs to include the 2nd one too when setting up the HTTPS connecting.
10-26-2023 03:17 AM
Was there ever a solution for this? We are currently in this same boat at the moment with HTTPS certificates. We have combined the certificates into one single chain .crt file to upload but we are running into a file limitation (5KB) issue. Our .crt file is 5.24KB.
10-27-2023 12:03 AM
No, unfortunately not. We still need to use security exceptions to connect to our CIMCs.
11-01-2023 05:41 AM
I've had the same issue, the webgui seems to have a 5k limitation.
However, the cimc cli does not.
The following procedure works with a machine and intermediate ca certificate:
1) ssh into climc
2) scope certificate
3) upload-paste-external-certificate
--> paste machine and intermediate ca certificate
4) upload-paste-external-private-key
--> paste private key
5) activate-external-certificate
--> your session will terminate and the cimc services for https/ssl will reload.
this is tested on c220m4 with 4.1(2k)
