04-30-2019 04:37 AM
Hi all,
i need to trunk between cisco catalyst and huawei S5720 in server client mode if possible or any other way to exchange their information and communication.
Pl suggest the solution.
Solved! Go to Solution.
05-01-2019 10:47 PM
@SherazAlvi9015 wrote:Thanks @Andrew Khalil for the reply.
I have already done this. but i need Client Server type connection so that different vendor may also pick the VLANs details from each other. In short VTP vs VCMP ... How could these protocols be integrated ?
to be more confident about that you can check this link,
https://forum.huawei.com/enterprise/en/Interworking-and-Replacement-Guide-VTP/thread/392883-861
specially this part:
In the C-H model, a Cisco switch directly connects to a Huawei S series switch that has no downstream Cisco switch connected.
When VTP is enabled on the Cisco switch to synchronize VLAN information, the Huawei S series switch cannot process VTP packets. Therefore, a VLAN needs to be configured manually on the Huawei S series switch.
Please don't forget to rate all helpful responses and mark solutions,
Bst Rgds,
Andrew Khalil
04-30-2019 04:48 AM
@SherazAlvi9015 Hello dear,
You can trunk between different vendors using the dot1q encapsulation which's open standard,
just you will need to configure the following:
on the huawei S5720:
#interface GigabitEthernet 0/0/13
#port link-type trunk
#port trunk allow-pass vlan all
#quit
On the Cisco SW:
#Interface f0/1
#switchport mode trunk
#exit
Only note that you have a use the same native vlan on both ports otherwise, you will get a miss-match.
Please don't forget to rate helpful replies and mark solutions!
Bst Rgds,
Andrew Khalil
05-01-2019 09:21 PM
05-01-2019 10:40 PM
Hello @SherazAlvi9015,
Unfortunately, these are vendors proprietary protocols, unlike the dot1q which is an open standard protocol that can run between different vendors!
Keeping in mind that not all VTP versions are compatible together even, i.e VTPv3 with VTPv1.
The best practice is to have 1 server for each protocol specified for each vendor.
Please don't forget to rate all helpful responses and mark solutions!
Bst Rgds,
Andrew Khalil
05-01-2019 10:47 PM
Bst Rgds,
Andrew Khalil
