Cisco 2801 router upgrade from RJ45 to Cisco HWIC-1GE-SFP Gigabit Ethe
NTrejos
Hello
I have a Cisco 2801 router and I want to upgrade the RJ45 to a  HWIC-1GE-SFP Gigabit Ethernet High-Speed WAN Interface Card. I had mixed answers with respect to compatibility. Does anyone know if this HWIC card is compatible with the router?
Joseph W. Doherty
Depends on the installed IOS.
According Cisco Gigabit Ethernet High-Speed WAN Interface Card  you need 12.4(15)T9 (or better) and IPBase (or better).
BTW, a 2801 isn't really a gig capable router (it can struggle even with its FE ports), and possible the module card interface might only support 400 Mbps.
Based on the provided search results, here is a summary of the bandwidth capabilities for HWIC (High-Speed WAN Interface Card) slots:
  • HWIC: The original HWIC has a bandwidth limit of 400 Mbps bidirectional.
  • Enhanced HWIC (EHWIC): Introduced with the ISR G2 x900 series, the EHWIC operates at 800 Mbit/s, doubling the bandwidth of the original HWIC.
  • Gigabit Ethernet HWIC: This type of HWIC supports Gigabit Ethernet connectivity, with a single SFP slot allowing for copper or optical connections. The bandwidth is not explicitly mentioned, but it is implied to be Gigabit Ethernet speeds (1000 Mbps).
I would take the "implied" with a very large grain of salt, as even the later EWIC modules are designed for 800 Mbps.
