How to monitor the status of a port-channel
vjunior
I want to monitor the status of my port channels, which are (P), (I), (w), and so on. I want to monitor the status of the port on a Cisco switch. Is this possible?
I found this OID: 1.3.6.1.4.1.9.9.285, but it is not found on all the switches and routers I tested. Could it be the IOS firmware version of the devices?
I am testing on the C9300-48T, IOS 16.06.02
marce1000
  - You may want to have a look at https://mibs.observium.org/mib/CISCO-LAG-MIB/
    and check if any OID's are available for your purpose.
  M.
