CISCO 2951 and 48port EtherSwitch module (baud issues)
alienkidmj12
Hi folks,
Seem to have ran into an issue, just purchased a 48 port module for my router. However it did not have any image, so i attempted doing a zmodem upload, but it was too slow. I changed the baud on the switch itself to 57600, and now i cant get back in to change it. All i get is awfull characters :( Surely ive not killed it already,
Does anyone know a work around ?
thanks
dave
20 Replies 20
Mark Elsen
 - Seems you have a baudrate-mismatch between the switch and your operator-infrastructure. Sync the baudrate settings.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
how do i achieve that,
im lost to be honest, been trying for almost 24 hrs
any advice would be gratefully, at my whits end now.
line con 0
line aux 0
 modem InOut
 transport input all
 speed 57600
 flowcontrol hardware
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 0/3/0
 script dialer gsm
 no exec
line 131
 autobaud
 no exec
 transport input all
 stopbits 1
line vty 0 4
 exec-timeout 30 0
 privilege level 15
 password 7 zzzzzzzzzzzzz
 transport input telnet ssh
line vty 5 15
 password cisco
scheduler max-task-time 5000
scheduler allocate 20000 1000
ntp server 194.35.252.7
end
i remember setting the etherswitch to 57600, obviously i cant get in now to change it, the line 131 only allows 115000 or 9600 baud.
i can connec to the main switch find using telnet or console, its only when i access the ether switch i have issues, doing the following
service-module GigabitEthernet2/0 session
dave
 - That is a chicken and egg problem ; because you are accessing it through a channel that has another baudrate then the module you are trying to access. Try tapping the space bar when the weird characters appear. If that does not help check how to factory reset the module so that it gets back to a standard baud rate.
M.
       Beauty and terror
      Just keep going
       No feeling is final
ive tried that, just wierd chars, i can take the module out but cant see any buttons. not sure if the settings are stored on the module or on the router itself, hard to tell - does anyone know this ? i can see a set header pins on the board but wouldnt know what they are, possible serial or something :( clutching straws here hoping someone has an answer :( cant see any batteries on the module either. dear me. i cant be the only one who had this issue, seems as though cisco need some sort of solution. perhaps giving us more options for baud on line 131, is thats infact the one i need to configure.
I guess you've loaded the wrong image in your router?
first remove the switch module and see if you can access the router-chasisis
remove the flash card and see if you can get into rommon mode
look at reset the chassis to factory defaults
 >>>>>>>>> confused by this commment, i can acces the 2951 okay, its the etherswitch i cannot access, as its on wrong baud rate.
>>> NA
>>> NA
how do i set a 2951 router to 57600 baud using config registers, ive tried
config-register 0x3122
but after reload, it reverts back to  0x2102
anyone any ideas ??? i thought if i made the router the same baud i could then connect to the switch which is at 57600 at the moment,
dave
found this procedure to change baudrate in rommon
Once in ROMmon, change the console baud rate from 9600 bps to 115200 bps to speed up the download time. Use the confreg command and complete the instructions presented on the screen.
rommon 1 >confreg
Configuration Summary
enabled are:
break/abort has effect
console baud: 9600
boot: the ROM Monitor
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
enabled are:
console baud: 115200
You must reset or power cycle for new config to take effect.
rommon 2 >
how do i enter rommon mode, ive tried configuring registers, i just cant
get there.
dave
midnight-cisco2951#service-module GigabitEthernet2/0 session
*Feb  7 17:32:51.691: %SYS-5-CONFIG_I: Configured from console by console
Trying 192.168.1.38, 2131 ... Open
* Unauthorized access prohibited
* You are connected to CISCO 2851 Router
* at ip 192.168.0.35
User Access Verification
Username: admin
Password:
midnight-cisco2951#show ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.7(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Mar-18 05:36 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
midnight-cisco2951 uptime is 9 minutes
System image file is "flash0:c2951-universalk9-mz.SPA.157-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 477184K/47104K bytes of memory.
Processor board ID FCZ1622202F
1 DSL controller
1 Ethernet interface
5 Gigabit Ethernet interfaces
1 ATM interface
3 terminal lines
1 Cellular interface
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2951/K9          FCZ1622202F
Suite License Information for Module:'c2951'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
datak9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2951'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            None                 None           None
data          None                 None           None
Configuration register is 0x3122
midnight-cisco2951#
its opn 57600 baud now,  still no luck connecting to etherswitch which is at 57600 baud
midnight-cisco2951#service-module GigabitEthernet2/0 status
Service Module is Cisco GigabitEthernet2/0
Service Module supports session via TTY line 131
Service Module is trying to recover from reset/shutdown
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module status is not available
midnight-cisco2951#conf term
Enter configuration commands, one per line.  End with CNTL/Z.
midnight-cisco2951(config)#in
midnight-cisco2951(config)#line 131
midnight-cisco2951(config-line)#speed ?
  <0-4294967295>  Transmit and receive speeds
midnight-cisco2951(config-line)#speed 57600
 Only baud rates 9600 and 115200 are supported
Failed to change line 131's speed
im unable to use 57600, wondering if this is a limitation of router, or ios ??
im really suprised some cisco employee has not given me a solution by now :(
it is my worklab, im studying cisco qual, so without this im kinda stuck... no progress
just need a definitive answer, can it be salvaged some how
dave
Step-by-Step Procedure
Perform these steps in order to recover your password:
  1. Either switch off or shut down the router.
  2. Remove the compact flash that is on the rear of the router.
    For more information, refer to Back Panel Slots and Connectors on the Cisco 2921 and 2951 Routers.
  3. Switch on the router.
  4. Once the router is on Rommon mode, reinsert the compact flash.
THIS IS NOT A PASSWORD ISSUE,
IT IS A BAUD RATE ISSUE
The Service Module Etherswitch 48port 1GB is running at 57600 baud
The router is running at 9600 baud on  TTY line 131,
I need to reset the service module to 9600 baud
See below,
There is an internal pin header on the board, does anyone know what this does, is it serial ??
You don't understand!
the procedure to get into rommon mod to configure the baudrate
starts the same as the password recovery procedure
once you have got into rommon mode you do not do the password recovery steps, but steps to change the baudrate
as in my post from ‎07-02-2019 04:20 PM
